OEM fluid test
09/20/2020 at 16:56 • 0 commentsOEM european power steering fluid (15-851OEM)
Appearance: green colored light liquid
May be similar to CHF 11S. Reported here 11S should be compatible with HNBR/NBR:
SRAM oring tested in fluid:
- OD swell 20% after 24hrs (10->12mm)
- Thickness seems unchanged
- Caliper seal thickness did increase ~10%, enough to make it unusable
SRAM oring should be EPDM. So maybe 851OEM oil has very similar compatibility to standard mineral oil?
NBR oring:
- No swell
VQM (silicone):
- No swell
https://forums.mtbr.com/brake-time/o-ring-material-question-680609.html
Synthetic hydraulic fluids
09/20/2020 at 02:21 • 0 commentsVarious available fluids found online that may be appropriate for hydraulics:
- Viscosity (40C): 18.7mm2/s
- Viscosity index: 313
- SDS indicates 68649-11-6 1-decene dimer hydrotreated (also used as a skin product, grinding oil, etc.)
- Recommended on MTBR forums many times
OEM power steering fluid (European):
- Contains highly-refined mineral oils
- Made by Recochem Inc code: 15-851OEM
- SDS has no useful information, other than not hazardous. So maybe does not have major additives?
OEM power steering fluid (Asian):
- code: 15-891OEM, probably the same as above product
Prestone European power steering fluid:
- Stated as alternative to CHF 11s, or CHF202 (which is partial synthetic)
- Contains "seal conditioners and anti-corrosion additives"
- Ingredients: different base oil, and a few additives (zinc and anti-wear)
FEBI hydraulic fluid M6162:
- Viscosity (40C): 16mm2/s
- Seems to be mineral based, not synthetic?
Synthetic DOT3 (eg lucas oil synthetic):
- Different base oil (9004-74-4), could be more hazardous
Advantage of synthetic:
- Wider temperature range
- Maybe more compatible with materials? (seems to not be the case)
Viscosity index: lower = change more with temperature, higher = change less.
Viscosity: higher = thicker.
Kinematic viscosity: how fast fluid is moving when force applied.
Links:
https://www.pinkbike.com/forum/listcomments/?threadid=140344&pagenum=3
https://forums.mtbr.com/brake-time/mystik-mineral-hydraulic-oil-brakes-1070783.html
https://www.ncbi.nlm.nih.gov/books/NBK304428/ (mineral oils study)
o-ring sizes
09/17/2020 at 03:42 • 0 commentsSRAM force 11sp brake caliper:
- 2pc 22.4 x 18 x 2.2mm square cross section (piston seal)
- 2pc 8mm x 1.2mm (inner seals)
- 1pc 10mm x 1.0mm (hose arm seal)
- 1pc 5 x 1mm? (bleed port seal)
Brake lever:
- ? piston o-ring seal bottom, top
- ? cable entry seal bottom, top
Piston: 17.85mm (aka 18mm)
Piston seal sources:
- Official seal/piston kit (sram # ..)
- MYA-018 is close
- Stack two 1mm or 1.2mm round (not thick enough)
- Use single ~18 ID x 2.5mm dia round o-ring (not ideal)
- Ebay: https://www.ebay.ca/ulk/usr/pavlina_kyrychova possibly
Different size piston available here (26mm OD) labeled as PE: https://www.aliexpress.com/item/4000509364502.html
o-ring compatibility
09/17/2020 at 03:36 • 0 commentsO-rings compatible with:
Mineral oil:
- NBR (nitrile/buna-n)
- PTFE, AU, FKM (fluorine green color)
- VQM silicone (maybe, 10-20% swell)
DOT5.1 brake fluid (DOT3, DOT4):
- EPDM
- SBR
- PTFE, FKM
Synthetic based hydraulic oils:
- EPDM
- SBR
Brakes that use:
- Mineral oil: Shimano, Tektro (Giant),
- DOT5.1: SRAM
