CYOCrawler: Open-source quadrupedal robot
10/30/2023 at 12:22 • 0 commentsInspired from what I have learned in building BOCA, we created CYOCrawler, an open-source quadrupedal robot. You can find more about the project here: https://hackaday.io/project/193061-cyocrawler-open-source-quadrupedal-robot
We are also launching CYOCrawler soon on Kickstarter, the fund will be used to mass-produce the PCB and lower down the overall cost of the robot, making it affordable for robotic/STEM education. Back us at: https://www.kickstarter.com/projects/cyobot/cyocrawler-building-tomorrows-innovators
BOCA inverse kinematics finalized and working
09/27/2020 at 06:46 • 0 commentsFirst working version of BOCA 8 DOF with inverse kinematics - source code and 3D design STL are available:
Find all the necessary files and components and instructions on my project repository here: https://projectcocoon.org/projects/27/boca-3d-printed-quadrupedal-robot#tab=logs&name=boca-mk11-working-212
