1Circuit diagram
[5v0]---+-------+--------------------------------[5v0] | | | | ,------------------(4)---------[GPIO-D7] | | | ,----------------(3)---------[GPIO-D2] | | | | ,--------------(2)---------[GPIO-D1] | | | | | ,------------(1)---------[GPIO-D0] | | | | | | | .--|-|-|-|-|--. | \ 5 4 3 2 1 / DB9/1 | \ 9 8 7 6 / | `|-|-|-|' | | | | | | | | +-}------------(Clk)--------[GPIO-D8] | | | | | R16 | | | | `-----^v^v^---+-------+---[GPIO-A6] (5) | | | | | | `-}-}-------^v^v^---' > | | | R19 < R1G | .--(8)--+ | > | | | | R29 | | | ,-}-}-------^v^v^---+---+---{---[GPIO-A5] | | | | | | | | | | | | | ,-----^v^v^---' | | | | | | | | R26 | | | | | | | | | | | | ,|-|-|-|. > | | | / 9 8 7 6 \ R2G < | | | / 5 4 3 2 1 \ DB9/2 > | | | '--|-|-|-|-|--` | | | | | | | | | | | `--}----' | | | `---------(1)----{---{---[GPIO-D9] | | | `-----------(2)----{---{---[GPIO-D10] | | `-------------(3)----{---{---[GPIO-D11] | `---------------(4)----{---{---[GPIO-D12] | | | [Gnd]------+-----------------------------+---+---[Gnd] Resistors: Rxy -> x -> Controller number y -> Pin Number / Ground RxG == Rx9 == 10K Rx6 == 6.8K (~70.2% of Rx9) -
2Code
Either download the source from here, or github (probably Github, as that will get realtime updates)
Place the code in : /path/to/.../digistump-avr/libraries/MegaUSB
Restart your Arduino IDE
Select Mega2USB from the examples menu
BlueChip
