Simple Add-ons (SAO)
A gateway to making your own Badge Add-ons
Simple Add-ons (SAOs) is a standard that enables anyone to make a PCB that can be attached to and powered by a SAO Capable device. SAO Capable devices take care of the power requirements so all you have to worry about is making your Add-on work and look cool!
Device makers, mainly Electronic badges made for conferences, can encourage others to attach Add-ons to their devices by adding the SAO port which is a simple 2x3 0.1" (2.54mm) header.
Simple Add-on is a fork / rebranding of the "Shitty Add-on" standard with the intention to make SAOs more accessible to a wider audience and provide a clear description of their purpose. As such, unless stated otherwise, documentation for the "Shitty Add-on" standard, specifically SAO169bis is still applicable to "Simple Add-ons". Pin out, foot prints, and parts necessary will remain fundamentally the same with a new name.
The Specs
Simple Add-on v2's specs are identical to SAOv169bis.  The first pin is VCC, power, and it is expected to be 3.3 Volts.  Second pin is Ground / Earth, third pin is SDA, fourth SCL, and the last two pins are for GPIO.  The only two pins that are always expected to work are VCC and GND, the other pins are optional.   If you are making an Add-on and would like to make use of Pins 3-6 you should coordinate that with Badge / Device makers or at least document it well so that badges that would like to accommodate that can do so.
The Footprint
As this standard remains compatible with the original "Shitty Add-on" standard it uses the same pinout.  The supplied "SAOv2.zip" is a updated and renamed version of the original SAOv169bis KiCad Footprints and Libary files that I created in 2019.  The changes made to the "SAOv2" part pertain to better dimensional accuracy and changing the square pad from "GND" to "Pin 1" which is VCC.
There are two foot prints provided for your use.  The "Badge" Foot print has an outline of the Keyed Female part on the Front Silk screen and on the Back Silk Screen has the pinout labled.  On the "SAO" Footprint the front is left completely blank while the back has labeled pins and an outline for the Male header.
The Connector
As this standard remains compatible with the original "Shitty Add-on" standard it uses the exact same parts.
The Add-on board will use a Male 2x3 2.54mm (0.1") Pin Pitch Shield header and the Badge / Host board will use a 2x3 2.54mm (0.1") Pin Pitch Female connector.   For mechanical security it is preferred that the female part use a Polarized Keyed part but a non-keyed connector will work.
Male - Add-on Side Connector
Female - Badge/Host Side Connector
Obtaining these parts is fairly easy.  The SAO side male connector is extremely common and is inexpensive on Amazon or Ali Express.  You can get them on Digi-key, Mouser etc as well but they will be considerably more expensive albeit probably higher quality.  If you're looking to stretch your dollar it's cheaper to buy in bulk on Ali Express otherwise Amazon will do just fine.
The Female part however is more difficult.  If you're building a device to host SAOs you can get away with a regular 2x3 female connector but it will have a poor grip on Add-ons and they will fall off unless the host is stationary.
The two least expensive sources for the female part is either on my (TwinkleTwinkie's) Tindie Store or Ali Express.
Tindie Store Listing: https://www.tindie.com/products/twinkletwinkie/10-pack-of-sao-female-keyed-connectors/
Ali Express Listing:  https://www.aliexpress.com/item/33060894189.html?spm=a2g0s.9042311.0.0.28904c4dBFB03G
If you'd rather not buy from myself or China you can get some made to order by contacting a manufacture such as "Sullins Connector Solutions", they are the ones who made the more "Square" Female connectors pictured above.  The rounder ones came from China.  They are about the same mechanically.
Here is a Digi-Key listing for the Sullins part, but I recommend going to their site and contacting them directly.  They are great and easy to work with but you'll be purchasing in minimum quantities of 1,000 and they are not cheap.  https://www.digikey.com/product-detail/en/sullins-connector-solutions/SFH11-PBPC-D03-ST-BK/SFH11-PBPC-D03-ST-BK-ND
Here are some example pictures of the connector in use for reference.
KiCad_SAOv2.zip
KiCad Footprints & Library Files for Simple Addon v2
x-zip-compressed - 2.55 kB - 10/03/2020 at 18:21
Download
  • 1 × Add-on Part - Male 2x3 6 Pins 2.54mm (0.1") Pitch Straight Pin Box Header 2 Rows, 3 Pins each, 6 pins total with a 2.54mm (or 0.1") Pin Pitch with Straight Pins, and a Box Shield around the header. Key (hole) should align with the top row.
  • 1 × Badge / Host Part - Female 2x3 6 Pin 2.54mm (0.1") Pitch Header with Polarizing Key 2 Rows, 3 Pins each, 6 pins total with a 2.54mm (or 0.1") Pin Pitch with Polarizing Key. Key (hole) should align with the top row.
  • Why SAO "v2"
    TwinkleTwinkie10/03/2020 at 20:25 0 comments
    While the current spec for "Simple Add-on" is identical to the latest "Shitty Add-on" v169Bis spec I have chosen to abandon the legacy numbering schema.  To prevent confusion with the original "Shitty Add-on" v1 spec I skipped over v1 in favor of v2.  This will also prevent any confusion as to which to use if someone looking for "Simple Add-on" finds the older SAOv169Bis despite them being functionally identical.
    Since there are no differences SAOv2 will of course be compatible with SAOv169bis and the original 2x2 v1 spec.
View project log
Ezra wrote 5 days ago point
is VCC 3.3v or 5v?
nvm i skipped past the part where it said that
Andy Geppert wrote 05/02/2024 at 13:43 point
@TwinkleTwinkie  can you add comments about the optional UART TX/RX pin usage here, if you agree it should be part of the official spec?
Blunt wrote 06/06/2021 at 03:33 point
On the Footprint section, you say “The "Badge" Foot print has an outline of the Keyed Female part on the Front Silk screen and on the Back Silk Screen has the pinout labled. “ but the Badge footprint (on the right, blue) is the male silk screen, and vice versa.
TwinkleTwinkie wrote 06/06/2021 at 11:42 point
it’s not.
