Battery Test
10/04/2020 at 13:40 • 0 commentsUsed different battery. Pi booted at about 6:30A. It has been idle for about an hour now, and the battery has gone down from 4 dots, to 2. ... well, it just dropped to 1, and the pi is flashing the low power lightning bolt at me.
The pi's heatsink was fairly warm.
It can probably get an hour off this cheapo battery, which is a bit old.
Hardware Test
10/04/2020 at 13:20 • 0 commentsPainters Tape. Adhesive of Champions.
Raspberry pi wouldn't stay powered on, and the tablet only would display no signal. :/
Had the tablet side usb plug inserted in the wrong plug. After disassembly, noticed that the usb-c to multi cable was plugged into the. -
Software Test
10/04/2020 at 13:11 • 0 commentsInstalling Ubuntu Mate on the Rasberry PI 4 seemed ok.
Add "drivers". I first saw the python version, then found that forcing wacom drivers in the
X11/xorg.conf.d/files worked perfectly https://askubuntu.com/questions/1000869/how-to-run-the-new-huion-tablets-on-linux/1263684#1263684Slightly laggy. ... <0.5 second delay? Only really noticeable going fast.
TODO add video/comparison video?
stephengeorgewest
