1Unpack Your Kit!
What's inside:
- 1 Pre-Assembled "I Voted" Blinky board
- 1 Battery
- 2 Magnets
- 1 Adhesive disk
2Insert Battery into Battery Holder
Note: Be sure to place the positive side of the battery facing up to match the marking on the battery holder.
3Place Magnets (optional)
The magnets are very strong, use caution when handling. Place one magnet on the battery holder, this will only work if the battery is installed. You can then attach it to any magnetic surface. If you'd like to wear your badge, you can use the two magnets as a "pin". Place one magnet under your clothing, and the other on top. Then place the battery holder over the magnets. An adhesive disc is provided in case you want to permanently attached your magnet to a surface.
4Turn it on!
Note: The Switch on the right side of the board turns the lights on and off. The switch on the left side of the board controls whether the lights are blinking or solid.
Alpenglow Industries
