FreeCAD utilizes a "one sketch creates one solid" approach to modeling, and as I tried to illustrate in the video, creating the "base" component consists of a sketch for each "solid to be", which is then "padded" (or extruded) into a the various solids that make up the base body.
I'm still learning, but for me, it is a very viable alternative.
Hi Dan!
Thank you very much, I'm hopefully it helps!
Thanks again!
Greg
