Overview of Machine
Front View
- Power indicator
- X-axis motor
- DC Spindle Motor / Plotter
- Working Depth Limiter
Rear View
- Vacuum System Connection
- Serial port (9-pin) for expansion units
- Serial port (25-pin) for connection to PC
- X Motor Connection
- Y Motor Connection
- Connection for plotter head
- ON/OFF switch with mains connector and fuses
- X Motor
- Y Motor
Plotter Board
- Normally Open Limit Switches for – Y axis
- Common terminal for Limit Switches
- Spindle / Plotter +DC Supply
- Spindle / Plotter –DC Supply
- Solenoid Actuator +DC Supply
- Solenoid Actuator –DC Supply
- NC
- NC
- NC
- Normally Open Limit Switches for +Y Axis
Controller Board
- Mains EMI Filter
- Transformer
- Rectifier (GBU4D) 34V DC Output
- Rectifier (GBU4D) 78V DC Output
- Rectifier (GBU4D) 11V Dc Output
- Processing Unit
- Stepper Motor Controller (L6203) DMOS Full Bridge Driver
- Plotter Head Controller
Plotter / Spindle Head
- Shock Absorber
- Solenoid
- Tool Changer Handle
- Mounting for Spindle
- DC Spindle Motor
- Vacuum Connector
himynameisNaim
Martino Ferrari
DIY GUY Chris
Ian Dunn
Doug Coffland
