Switch Testers
02/21/2021 at 14:47 • 1 commentI just got a set of 13 different Kailh Choc switches, to see which ones are best for a given use case, and I needed to mount them to something — the Keeblet is just the perfect vehicle for this! Since the two red switches -- Kailh Pro and Transparent Red — are practically identical from the point of view of feel, I only needed to make 2 new Keeblets, for a total of 12 switches:
The transparent key caps are perfect for this, because you can see which switch is which without having to remove them!
PCB Design
10/11/2020 at 18:13 • 0 commentsAs usual, everything starts with the PCB design.
Nothing fancy. The minimal SAMD21 schematic with USB, plus six keys with diodes, a LED and a programming header. As usual in my projects the header has staggered pins to allow plugging in a male header without soldering.
The board will use choc switches, because I really like them. In hindsight, I should have designed some kind of a frankenfootprint so that any switch could be used — maybe I will do that in the next version.
deʃhipu
