I've been building Raspian nodes with external storage for awhile. I've found the recent changes to the boot eeprom to work just fine to boot from USB. With Raspian. With Ubuntu - not so much. At this point, I consider it a bit of a rabbit hole. So I'm fine with booting initially from the MicroSD card. It doesn't get mounted - and that is perhaps a good thing as I can still debug a boot problem separately from the state of the MSD device.
The downside is that after kernel rebuild - that kernel is not installed automatically. So I'm a few revisions behind already. Resolving this issue with automation is currently deferred. Once I figure out a manual method that is reliable - I'll document that here after some testing.
Another note is the hardware used. The PCI-e to USB bridge boards I'm using use the RTL9210B-CG chip on a generic adapter. The good thing is: no heat issues. At all. The problem? The device has a firmware setting that turns off power ( IOERROR! ) after 10 minutes of no access. The upside? Microk8s hammers that disk regularly - so as long as Microk8s is running properly - the disk stays on.
I disable all that power stuff ( to no effect, apparently ) with:
- Disable sleep
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
- Re-Enable sleep
sudo systemctl unmask sleep.target suspend.target hibernate.target hybrid-sleep.target
