Running a PCB on the Machine
After a lot of work, testing, debugging, and fixing, the machine is up and running and capable of assembling a PCB. There's still work to be done to make things easier to use. A new strip feeder design is likely. Rearranging the build table is coming in the near future. Overall, though, the machine works well and is really accurate.
