1Disassemble Google Nest Mini (2nd Gen)
2Remove board, antennas, etc from top of speaker unit
We don't need to privacy invading, un-"hack"-able components in here
3Test UBEC
Make sure you are getting the desired voltage before you go plugging things in
4Strip USB sound card
take components of USB sound card to get the profile a thin as possible
5Solder the USB sound card directly to the Pi
I used this as a wiring guide: https://www.grappendorf.net/tutorials/nerves-pizero-edimax.html
6Solder audio mixer circuit
I use 2x 100 ohm resistors, you may want to go with higher values (ie. 1k ohm)
7Solder in the audio amplifier
Solder the audio in, audio out and power to the audio amplifier.
8Solder the UBEC to the Pi
Space saving, I soldered straight to the header pins for 5V and Gnd.
9Prepare the MicroSD with Raspberry Pi OS
Burn the latest Lite image to the SD card and set it up for headless operation, I created a wpa_supplicant.conf file for my home wifi network and created an ssh file to start the ssh daemon by default.
https://www.raspberrypi.org/documentation/configuration/wireless/headless.md
10Make the USB sound card the default audio device
I used this guide: https://nixingaround.blogspot.com/2016/11/raspberry-pi-zero-usb-audio.html
You should probably reboot here.
Marcus Berg
