PressurePlate.scad
See STL description
scad -
747.00 bytes -
10/30/2020 at 21:40
Download
PrintHead_09.scad
See STL description. This has a three major part defined, lines must be uncommented to create the STL separately for the back plate, the top grill and the template for the aluminium heat sink.
scad -
7.31 kB -
10/30/2020 at 21:39
Download
PressurePlate.stl
This slides along the top rail of the X-Axis rails and pressurises the head against the top rail. Ths in turn controls how hard the nozzle is held against the print job and how much pressure is required to activate the Z-Axis switch.
Standard Tesselated Geometry -
66.28 kB -
10/30/2020 at 07:16
Download
PrintHead_09.stl
The large blue wedge that mounts the new Print Head assembly onto the X-Axis gantry slider. It holds the back heatsink, which holds the hotend. The Cooling fan and extra heat sink is mounted on the backplate heat sinks. It also house the pressure plate system that controls the pressure required to activate the Z-Axis limit probe.
374.72 kB -
10/30/2020 at 07:15
Download
backplate_09_template.stl
This is a template for the 3mm aluminium plate used for the main heat sink.
241.26 kB -
10/30/2020 at 07:15
Download
TopGrill.stl
A bit of bling in some ways but now has the job to hold the spring that presses on the Pressure plate.
51.80 kB -
10/30/2020 at 06:50
Download
