ROM-emulator
Emulate a small size ROM with a RAM and Arduino with Intel-HEX interface
ROMemu is a combination of software and hardware that allows the usage of modern software development tools for simple, old style single board computer systems. It emulates an (EP)ROM programmer to the development software and an in-circuit ROM/RAM on the board. With WR* signal wiring it is accessible as RAM from the SBC.
The firmware is stable for some time (developed that with the prototype shield) and the hardware is just debugged on the v1.1 PCB.
ROMemu is a combination of software and hardware that allows the usage of modern software development tools for simple, old style single board computer systems (SBC). It emulates an EPROM programmer to the development software and an in-circuit RAM or ROM to the SBC.
The current version 1.1 uses an Arduino Mega 2560 with a shield containing a 32 kByte RAM-chip which is (partially) readable by the SBC-processor. The Arduino USB-connection is available as serial port to the development system. This allows to write Intel-hex data to the RAM.
ROMemu has two modes;
* SBC-mode where it is visible from the host computer and all Arduino pins (data, address, control) are tri-stated,
* Arduino-mode where it is isolated from the host and accessed by the Arduino. There is no synchronisation, but as long as the SBC isn't executing code from the emulated memory, the SBC shouldnt crash (mine didn't).
Technical details.
The basis of the ROMemu is an Arduino shield with a static RAM chip, fully connected to Arduino pins. Additionally three 74HCT244 connect address and control lines and a 74HCT245 connects the data lines of the host SBC. In this mode all Arduino lines are in tri-state mode. An extra signal, ArduinoOnline, can isolate the RAM from the SBC. An 74HCT02 74HCT27 controlling the 74HCT245 buffer makes sure the RAM is visible from the SBC while reading.
A short flat cable and an adapter board (pod) makes sure the RAM-chip signals are properly configured for the socket. The pod consists of two parts, an adapter between the RAM-pins and the pins provided by the socket and a set of pins for the socket. A pod configuration has to be made for each  socket type you want to support.
There is a github page at https://github.com/electrickery/ROM-emulator.
Image with the board patch from 1.1 to 1.2
JPEG Image - 334.56 kB - 07/07/2021 at 06:59
Preview
ROMemu0.5.ino.zip
Copy of the latest Arduino firmware (also on Github: https://github.com/electrickery/ROM-emulator)
Zip Archive - 3.49 kB - 12/24/2020 at 17:11
Download
emuPodKicad.zip
KiCAD files for the flatcable-socket board, with signal pads for patching. These are the 1.1 version files with some extra patch pads. Quite optional, as the pins are available too.
Zip Archive - 7.09 kB - 11/01/2020 at 14:37
Download
socketAdapter24.zip
Adapter to the 24-pin socket.
Zip Archive - 4.24 kB - 11/01/2020 at 14:37
Download
ROMemu1.2.zip
KiCAD files for the Arduino Mega 2560 shield. Fixed, but unproven.
Zip Archive - 28.25 kB - 11/01/2020 at 14:35
Download
View all 7 files
  • Added Motorola Exorciser S1 record format
    fjkraan07/18/2025 at 12:30 0 comments
    This minor firmware update implements the Motorola Exorcizer format.
    -- ROM emulator v0.11.4 --
    Operational commands:
     Cssss-eeee-tttt - Copy data in range from ssss-eeee to tttt
     D[ssss[-eeee]]- Dump memory from ssss to eeee
     E             - Generate hex intel end record
     Fhhhh         - AddressOffset; subtracted from hex intel addresses
     Gssss-eeee    - Generate Motorola Exorciser S1 records"));
     H             - This help text
     :ssaaaatthhhh...hhcc - accepts hex intel record
     ;ssss-eeee    - Generate hex intel data records
     Kssss-eeee    - Generate checksums for address range
     Maaaa-dd      - Modify memory
     O             - Toggle echo
     R[0|1]        - Switch the RESET relay
     S1ccnnnndddd..ddss - accepts Motorola Exorciser S1 record
    Test commands:
     A             - test 32 kByte RAM with 00h, 55h. AAh and FFh patterns
     Bpp           - blink pin p (in hex)
     Nssss-eeee:v  - fill a memory range with a value
     Tp            - exercise port p
     U             - view ports C, L, A, CS, OE, WR, ARDUINOONLINE
     Wpp v         - Write pin (in hex) values 0, 1
     ?             - This help text
  • ROM-Emulator simplified diagram
    fjkraan08/09/2024 at 11:58 0 comments
    Here a diagram showing how the ROM-Emulator works. In operational mode, the RAM chip is connected through the buffers and POD converter to the socket of the target board. All the Arduino pins connected to the RAM are tri-stated, so the processor on the board sees the contents of the RAM.
    When the Arduino accesses the RAM, the buffers are tri-stated, isolating the RAM from the board. The processor would see FFh in the memory region addressed by the socket. The Arduino can now fill the RAM with data received from the PC, or change it with its internal commands.
  • Simple GUI program for configuration & uploading
    fjkraan07/21/2024 at 10:45 0 comments
    Just now I added a simple python3/wxWidgets program to the GitHub page (https://github.com/electrickery/ROM-emulator?tab=readme-ov-file) for those with a command-line allergy. It is still quite rough, and only really tested on my Linux system, but should work for Windows and MacOS too, as it is based on the wxTerminal.
    It assumes versions of Python3 and python-wx are installed on the system.
    It is very basic, but it finds and configures the serial port at startup, and has a nice File > Download Hex file menu option. It even lists the help text with Help > Help!
    Some issues in version 0.1:
    • Only tested on my MxLinux.
    • It adds more linefeeds than needed to the ROM Emulator output
    • It converts all typed text to upper case (seems to be a wxWidgets bug)
    • Hex file offsets should be entered into the terminal, no nice field and button (yet)
  • Minor updates
    fjkraan02/09/2023 at 09:24 0 comments
    The hardware and software works good enough for my needs, so only small updates:
    • Added combined echo and CR support for terminal mode,
    • Replaced the python3 romEmuFeed program with a newer version with better argument handling and made the tty port an argument too.
  • Arduino firmware and Python upload program update
    fjkraan02/05/2022 at 20:22 0 comments
    Updated the Arduino firmware and Python upload program, to reliable upload hex files produced by z80pack/z80asm. New versions at https://github.com/electrickery/ROM-emulator.
  • Improved 2716 emupod wiring
    fjkraan12/21/2021 at 14:19 0 comments
    2716
    28p cable header    24p socket header    remark
        1  A14                -             connect to GND
        2  A12                -             connect to GND
       20  CS*              18  CE*
       22  OE*              20  OE*
                            21  Vpp         connect to Vcc
       23  A11                -             connect to GND
       26  A13                -             connect to GND
       27  WE*                *             connect to Vcc or the WR* signal
       28  Vcc                -             not connected
  • ROMEmu assisted workflow
    fjkraan09/23/2021 at 16:19 0 comments
    My primary usage for the ROMEmu is writing and testing software for simple a Z80 SBC, the Multitech MicroProfessor MPF-I. The ROMEmu allows me to minimize the number of 'moving parts' while developing.
    One time setup:
    - connect the ROMEmu to the target system using a ROM or RAM socket mapped somewhere in the address space. For a startup ROM the SBC should be halted.
    Then it is mainly this iteration:
    - Edit and assemble some code for the destined address in the target memory space on the cross-assembler PC,
    - Upload the hex-intel file to the ROMEmu with the python script,
      For example 'python3 romEmuFeed.py lcdtest.hex 2000' The second argument compensates for the address difference between ROMEmu and target system
    - Execute the program in the ROMEmu memory. For the MPF-I this means 'RESET'; 'ADDR' 2000; 'GO',
    - Evaluate the program and restart at the edit step.
  • EmuPod & SocketAdapter information
    fjkraan08/02/2021 at 10:59 0 comments
    The EmuPod and SocketAdapter boards adapt the flat cable to a specific socket. The flatcable carries all signals from the 32kByte RAM, a 62256/D43256. The EmuPod transforms those to mimic the ROM signals. The SocketAdapter adapts to the physical socket form.
    Each target ROM has a different pin layout, so expect to reserve a set of these boards for each ROM. Not all pins will change, thanks to the JEDEC standard, but some will. The ROMEmu optionally also allows writing to the RAM if a write signal is available, complicating the configuration somewhat. Unused address lines are connected to GND, to address the lower area of the RAM. An unused write signal is tied to Vcc.
    Adding headers to the EmuPod:
    • the cable header is placed on the component side, the side with the white silk-screen markings
    • the socket adapter header is placed on the solder side. This to prevent the signals to be mirrored for the SocketAdapter. If you use a direct flatcable-socket adapter, then place the socket adapter header on the component side too.
    SocketAdapter remarks:
    • the header from the EmuPod is placed on the component side, the pins to the socket on the solder side. Make sure you use special socket headers with round pins, the usual flatcable header pins are to big. To protect the socket header pins from breaking off (and having you to resolder the header!) place at IC-socket on them. These are much easier to replace.
    Some EmuPod wiring configurations. Only the 2532 one is properly tested!
    Note: the cable header numbering used is the not the  standard Odd-Even order, but a Counter-Clock-Wise order, the same as used for I.C-sockets.
    This is for the 2532 EPROM socket (EmuPod24/SocketAdapter24):
       20  CS*              20  CE*
       22  OE*              22  OE*
       23  A11              18  A11
         -                  23  Vpp         connect to Vcc
    This is for the 2732 EPROM socket (EmuPod24/SocketAdapter24):
       20  CS*              20  CE*
       22  OE*              22  OE*
       23  A11              21  A11
    This is for the 2716 EPROM socket (EmuPod24/SocketAdapter24):
       20  CS*              20  CE*
       22  OE*              22  OE*
       23  A11              21  A11
    This is for the 2764 EPROM socket (EmuPod28/SocketAdapter28):
    28p cable header    28p socket header    remark
       26  CE2                              not connected
          -               26 NC             not connected
       27  WE*              -               connect to Vcc or the WR* signal
                          27 PG*            not connected
    This is for the 27256 EPROM socket (EmuPod28/SocketAdapter28):
        1  A14              27  A14
         -                   1  Vpp        not connected
       26  A13              26  A13
    This is for the 62256 RAM socket (EmuPod28/SocketAdapter28):
        1  A14              27  A14
       26  A13              26  A13
       27  WE*              27  WR*
  • Fix for ROM Emulator 1.1 Mega boards
    fjkraan07/07/2021 at 06:58 0 comments
    The 1.1 board did seem to work in some conditions, but wasn't really universally usable. This is a fix for the board, making it compatible with the 1.3 design. I didn't need more boards, so haven't really ordered and build any 1.2 or 1.3 for testing. The modification for 1.1 described here does work.
    - replace the 74LS02 at U2 with a 74LS27
    - cut trace to U2-1
    - cut trace to U2-2 (component side)
    - cut trace between U2-6 and U2-7
    - cut both traces to U2-12
    - cut trace between U2-8 and U2-9
    - connect U2-9, U2-10, U2-11 to U2-7 (unused port)
    - connect U2-1, U2-2, U2-13 to U2-6
    - connect U2-4 to U6-7 (H1, buffered board OE*)
    - connect U2-5 to U5-1 (H0, buffered board CS*)
    - connect U2-12 to U3-19 (board read)
    See the boardPatch1.1to1.2.jpg image
  • ROM-emulator application
    fjkraan12/26/2020 at 21:08 0 comments
    An usage for the ROM-emulator just went live at GitHub: https://github.com/electrickery/Z80SerialMonitor
View all 10 project logs
