« Back to project details
Code for the ATMEGA328PB
10/30/2020 at 15:35 • 0 commentsHere is the code for the ATMEGA328PB
Here is the code for the ATMEGA328PB #include <avr/io.h> #define F_CPU 20000000UL // Use external 20 MHz clock, set to external oscillator in the fuses #include <util/delay.h> const uint8_t MAX_CAP_VOLTAGE = 145; // Assume output of cap is more or less at ADC const uint8_t START_CAP_VOLTAGE = 130; // When to start charging - hysteresis const uint8_t COUNT_FET_DEFAULT = 0; // When starting to charge, the lower FET on time const uint8_t COUNT_LOW_DEFAULT = 200; // The starting count for all switches off // Enumerated type for the state machine typedef enum {IDLE, CHARGING, STOP} state_var; int main(void) { // Variable to hold the state volatile state_var the_state = IDLE; // The low side on time uint8_t count_fet = COUNT_FET_DEFAULT; // The idle time when everything is low uint8_t count_low = COUNT_LOW_DEFAULT; // PB0 for V high (high side) // PB1 for V low (low side) // PB2 for trigger DDRB = 7; PORTB = 0; //DDRD = 255 - (1 << 5); // Setup the analog comparator, set bandgap reference (instead of AIN0) ACSR = (1 << 6); // Setup the ADC (use AVCC, left adjust, and ADC0 as the input) ADMUX = (1 << 6) + (1 << 5) + 0; // Enable ADC, start it up, auto trigger, divide by 128 for prescalar ADCSRA = (1 << 7) + (1 << 6) + (1 << 5) + 7; // Free running mode ADCSRB = 0; // At start, just wait in case of issues with programming _delay_ms(3000); while (1) { if ((PIND & (1 << 5)) == 0) { the_state = STOP; } if (the_state == IDLE) { // Idle state // Wait to let the ADC readings settle _delay_ms(3); if (ADCH < START_CAP_VOLTAGE) { // Begin charging // Initialize lower FET on time count_fet = COUNT_FET_DEFAULT; count_low = COUNT_LOW_DEFAULT; // Update state variable the_state = CHARGING; } } else if (the_state == CHARGING) { // Charging state for (uint8_t qq = 0; qq < 128; qq++) { // Cycles of current control // Charging loop // Turn on the high side FET PORTB = 1 + 4; PORTB = 1; PORTB = 1; PORTB = 1; PORTB = 1; PORTB = 1; PORTB = 1; PORTB = 1; PORTB = 1; PORTB = 1; PORTB = 1; PORTB = 1; // Turn off the high side FET, prevent shoot-through PORTB = 0; PORTB = 0; PORTB = 0; // Turn on the low side FET for (uint8_t jj = 0; jj < count_fet; jj++) { PORTB = 2; } // Turn off the low side FET, all low PORTB = 0; for (uint8_t jj = 0; jj < count_low; jj++) { PORTB = 0; } if ((ACSR & (1 << 5)) == 0) { // Current too high if (count_fet < 255) { count_fet = count_fet + 1; } } else { // Current too low if (count_fet > 0) { count_fet = count_fet - 1; } if (count_low > 0) { count_low = count_low - 1; } } } if (ADCH > MAX_CAP_VOLTAGE) { // Done charging, set to IDLE the_state = IDLE; } } else if (the_state == STOP) { PORTB = 0; _delay_ms(1); if ((PIND & (1 << 5)) == (1 << 5)) { the_state = IDLE; } } } }
