1Step 1
took the print out of the sculpture pattern in a paper in the required dimension
2Step2
Made 5 brass rodes with 30cm length each.
3Syep3
Placed the brass rodes on the top of the patter and made the required shape by cutting and bending the brass rodes with reference to the pattern.
4Step 4
finished soldering then cleaning use this brush
5Step 5
Use brass wire .5mm
Smd 1206
the last stage of metal king.eye lighting useing for smd led 1206 yellow color
