The compartment that I found myself printing the most often was a variation that Raaco does not offer. For small components -- like 3MM hardware or individual transistors -- even a quantity of 50 didn't fill up the smallest of inserts, the A9-1.
The 1/2xA9-1 was an attempt to follow Raaco's semi-weird naming convention and subdivided the smallest insert.
As my confidence in 3D printing improved, the insert walls went from 3mm walls to 1.6mm to the final 0.8mm.
Like to 3D print? Check out Thingiverse or OnShape.
Edit : Added dimension drawings and links to Thingiverse or OnShape.
