Very Simple Dual 3xINPUT 1xOUTPUT for Eurorack/Kosmo Synthesizer System
Schematic_3x Input 1x Output Mixer Building Blocks_2021-02-09.pdfWhat Mixer Building BlocksAdobe Portable Document Format - 395.37 kB - 02/09/2021 at 22:33 |
Schematic_Simple Dual Mixer_2021-02-06.pdfAdobe Portable Document Format - 78.80 kB - 02/06/2021 at 23:05 |
Half of the schematic for a Simple eurorack mixer. You can Use a TL074 or TL072. Depends on how many Op amps you decide for your mixer.
The First op amp(U1.1) Inverts and Amplifies the mixed voltages with a Gain of 1.
Then that is fed into the second op amp(U.1.2) Inverts and Amplifies the mixed signal phase back to the Original Phase with a Gain of +1.
This is a really good starter module. Video made by Synth Diy Guy SDIY Class # 10 - Building a dual Mixer . He Explains how Op amps Function and shows the Basic schematic. Based around the TL074 Quad Op amp. Here is some other layouts for the panel that I ended up not using.
