Simple Mixer
02/06/2021 at 22:45 • 0 commentsHalf of the schematic for a Simple eurorack mixer. You can Use a TL074 or TL072. Depends on how many Op amps you decide for your mixer.
The First op amp(U1.1) Inverts and Amplifies the mixed voltages with a Gain of 1.
Then that is fed into the second op amp(U.1.2) Inverts and Amplifies the mixed signal phase back to the Original Phase with a Gain of +1.
Simple starter Module For Euro Rack
11/01/2020 at 23:31 • 0 commentsThis is a really good starter module. Video made by Synth Diy Guy SDIY Class # 10 - Building a dual Mixer . He Explains how Op amps Function and shows the Basic schematic. Based around the TL074 Quad Op amp. Here is some other layouts for the panel that I ended up not using.
