A Field Oriented Control Electronic Speed Controller for the Raspberry Pi!
In the summer months leading up to my first major log, I learned a lot about the future of electronics. The fact is, the world is getting efficient and one method of getting there is going to be increased usage of GaN devices. For this reason, I've built my latest revision of the Pi-ESC system around a GaN design. Fast transients, fast signals, and fast cars!
So, here is the board. Files will follow after I sort them out.
On paper, the components can handle 20kW continuously! With the pitiful amount of copper I had within the board area of a Raspberry Pi and 4 layers, and 4 ESC channels, I would conservatively rate the board at 2kW. At 99% or so efficiency, that's just 20W of power that needs to be dissipated, meaning you can reduce the weight contributed by a bulky heatsinking solution.
Almost no area is spared from being functional. Where large area is unused, like the center of the bottom side, many solder apertures on the copper forms a solder or high emissivity heatsinking structure. When painted or coated with a high emissivity material like carbon conductive assembly paste (stencil applied carbon resistor material), improved thermal performance will result because of its very high emissivity.
After hundreds of milliamps released the VOC smoke of heck, it turns out, using optoisolators as gate drivers is a bad idea, and I wasted $50 of optoisolators and a board revision.
There's a reason I haven't released schematics yet, it would be like encouraging you to hurt yourself.
I'm going to revise this with the Microchip ATA6844 driver, and may switch to the Teensy dev environment, after an enlightening chat with Kai Yin. Thanks for stopping me from doing something dumb.
I appreciate your insightful idea, and I intend to implement it on my website as well. You can check it out here for more details https://therummyapk.com/
you really shar a good idea i also use this in my site you can see here https://buyozempiconlineuk.com/
"This is a good idea, I will also use it on my website."https://en.wikipedia.org/wiki/KDKL
