Wi-Fi LED strip controller made with few goals:
- Dual voltage support 12V and 24V
- 2 independent channels for color temperature adjustments
- No high pitch noise in all modes
- Powerful enough to handle current up to 17.5A (in total, limited by connectors)
- Control buttons on the device body
- Connectors for external buttons
- Can be used with already installed LED strips
- Support of open source firmware, like https://esphome.io/
Hello,
I attached current schematics to the post,
Output terminal is GND_1 | V+ | GND_2 | V+
It is made this way to control either 2 independent single color LED stripes, or to control one with Warm white/Cold white LEDs
