A while ago, I discovered the STM32F020F4P6. It is the lowest-end Cortex-M0 microcontroller ST offers and it is happily supplied by various Chinese stores for 30 to 80 cents per piece. Albeit being very cheap, it offers quite a lot of functionality! It runs at 32 MHz, has 16K of flash and 4K of RAM, an 12 bit ADC, SPI, I2C, a bunch of timers, …
It is a tiny controller, but for most of my applications it's more than enough. Read in some sensors, control some outputs via a state machine, datalog something to a SD card – why should I use a giant controller when I can have a cheap, small and simple solution?
This project started because I wanted to have a nice prototyping platform for that particular controller, just to test some things before I design a real PCB for the project. Yes, Chinese-made boards exist. Yes, I could just step up to F1s and use a cheap “Blue Pill” board like everyone else. But all those readily available boards have, in my opinion, one major flaw. Read more »
fruchti
Neven Boyanov
zacnotes
MoCo Makers
AKA
Did you try to integrate it with individual CDN platform. Try apachis program to get result.
