some photos
04/06/2021 at 19:40 • 0 commentsHere are some photos taken with this lens.
I do not have a good scanner for negatives so I used a cheap camera to take photos of the negative images. That's why they are not good looking and a bit blurry.It turned out the best photos were trees.
Another one, together with an image with the standard 2,8/35mm lens shot from the same position.![]()
I did this project for fun and therefore claim it success.
A lot can be optimized but I'll keep it as an experimental lens just as it is right now.
Update: I just made some real photos from the negatives which are easier to scan.![]()
It seems as if the focus lies inside the tree's crown but is very narrow.
As previously stated, it was only a fun project an has lots of space for improvements.
