13/4 inch PVC pipe
First you need 3/4 inch PVC piping.
2Cutting PVC pipe
Cut a 5 inch piece of the pipe off.
32 PVC Cap(s)
Obtain 2 caps that fit the 3/4 inch pipe piece.
4Drilling holes
Drill a hole for the top big enough to hold your antenna.
5Placement of the antenna
Insert the antenna into the hole use the cord that runs from the antenna to the RTL-SDR dongle.
6Insertion
Curve the cord with the rest of the cord facing upwards.
7Wrap
Push the cord down into the pipe the excess of the cord can wrap around the pipe.
8Drilling the holes again
Then drill a hole big enough to fit your screw-able top of your stand.
9Bottom
Put the bottom piece on.
10Screw it in
Screw in your stand.
