A very minimal design to break out some common peripherals of the CM4. More a quick demonstration than anything else.
Very nice project😊!
I am a beginner in PCB designing. Would you list down the name of the used components in the board
Thanks in advance
I love this project! What make/model PCB mill did you use?
It is just amazing how far we've come in terms of diy homemade engineering, thanks for sharing. I have a question about the usb connection: I see that you left the otg_id floating, does the raspberry pi acts as a host or a device in this case? I'm thinking of connecting the otg_id to a microusb id pin, but I saw in the documentation that the otg functionality is not fully implemented. My idea is to use a single microusb connection as a device and also as a host with an usb A adapter.
Damn, son! :)
I take back everything bad I've ever said about milled PCBs. This one is sweeeeet.
Hi, May I ask which Milling Machine or technique did you use for this beautiful routing?
