LED indicator visually shows you the received signal strength RSSI in dBm from a Wi-Fi router. The indicator is implemented using three LEDs:
- green LED is used to indicate a good signal strength (-60...0 dBm),
- yellow LED is used to indicate a medium signal strength (-75...-61 dBm),
- red LED indicates a poor received signal strength ( < -75 dBm).
