gqr.sh
This script can be saved to the desktop or invoked on startup. When you execute from the desktop, select Execute, not Execute in Terminal. If we fail, adjust the sleep timing and make sure that only the Audio and Main toolbar are visible as xdtool is only using those to start everything properly.
x-sh -
809.00 bytes -
11/24/2020 at 05:14
