Prototype build
A project log for LiFePO4wered/Pi400
Simplified low cost UPS and battery power for the Raspberry Pi 400
patrick-van-oosterwijckPatrick Van Oosterwijck • 11/23/2020 at 05:37•0 Comments
After creating the design, I ordered prototype PCBs and stencil from JLCPCB.  This log documents the build of three prototypes.
The SMT part of the build went very smoothly.  No obvious shorts I needed to deal with.  Two parts are still missing: the button (SW1 which didn't arrive yet and I'll add later) and there's a footprint for a low cost 6-pin Padauk micro (U7) which will be used to enable firmware update of the MSP430 over I2C BSL.  No point in mounting an OTP micro until I've figured out its programming. :)
After such a smooth SMT build, connecting the headers unexpectedly was a whole lot more troublesome:
Ugly, I know.  I had a lot of trouble getting both the pads and pins to wet and connect.  In hindsight, the pads are too small as they are completely under the pin so they're hard to heat together with the pin.  Also, the board is thinner than the spacing between the two rows of pins, so there's a gap that needs to be bridged.  I'll have to investigate thicker PCB options for a better fit.
I got a prototype together in the end:
The battery holder for an 18650 LiFePO4 is on the bottom of the board.  I was able to confirm some basic functionality:
This last test was really important, the whole concept of this UPS would stand or fall with the result of this test.  And as far as I could tell, it passed with flying colors!  I could have the boost converter enabled and apply and remove external power at will, the boost converter would just take over when external power went away and stop providing power when external power came back.  You could see the voltage on the scope go from 5V to 4.85V and back to 5V and the whole thing would be completely glitch-free!
Next things to test:
Once these are confirmed, I can start writing the firmware for this new micro.  It's still an MSP430 like in the #LiFePO4wered/Pi+, but this is a newer generation device with FRAM and enhanced peripherals compared to the part I used in previous designs, so some porting will be necessary.
