Iv been working on documenting different aspect of the program and have put several links up for YouTube videos that cover some of what I have my setup doing, install of the program, and building of the style of relay box that I use to control various stuffs.
Currently Iv got Lua pi pan up and running several different things in my home and I wanted to go over everything it is currently doing in a bit more detail.
First of all it does all the thermostat logic for my room, my dads room, my green house, and my aquaponics system.
It also controls the timing on a pump for my aquaponics system as well as controlling the light for my sump tank to keep my koi happy.
I like to check out my green house in the evening so I have a motion sensor that turns on a relay powering a string of LEDs when its dark to give me plenty of light to work by. Iv also got a motion sensor in my room attached to a single LED that turns on when its dark to help me avoid stubbing my toe. It also keeps track of near by mac addresses by continuously scanning with the wifi so if my phones not found, meaning im not at home and anyone enters my room the motion sensor will trigger a piezo buzzer to go off and send a txt message to my phone alerting me.
Several buttons control aspects of the system and finally the master pi runs a local web server used to control the system as well as showing data from sensors on a graph.
PhilMo6
Brenda Armour
Norbert Heinz
Timo Birnschein
Mark Heywood
