Did some minor code updates, I figured out that the DHT22 module no longer worked due to the change in the gpio library used so im working of fixing that now. Iv also made a new video showing how to configure a master or slave node.
A project log for Lua Pi Pan
Lua pi pan is my take on home IoT using lua and raspberry pi's
