The temperature outside is over 100 degrees Fahrenheit (38 C) here in Tucson, Arizona and so now I get to see how well my machine holds up in extreme heat. I measured the garage at 98 F (37 C) today around 2 pm, that should be the peak temp for the day. It was hot enough that my stepper motor drivers were a bit unstable, when powering up the machine they tended to get stuck in a runaway oscillation between two poles. However once I got that settled down the machine ran just fine.
More interestingly the plastic parts on the machine seem to be holding up well. I printed everything out of PLA rather than using a higher temp filament like PETG or ABS so I'm a bit worried about it all warping in the extreme summer heat. However I can't see any evidence of warping or cracking and nothing is loosening up even.
I do have some separation on my electronics housing, however this was made too small and I have a lot of thick cables crammed into the housing with only the force of the lid keeping it all in place. Coming up with a better way to manage the electronics is on my list, but not high enough yet. At some point in time I would like to have a 5th stepper motor, maybe then I will come up with a better way to house the electronics.
The spindle on the other hand got up to 135 F (57 C) when running. It held that temp consistently over the hour I ran it but still it is quite warm. That may not lead to a long lasting motor, time will tell.
