1Getting Started
- Download Raspberry Pi OS: https://www.raspberrypi.org/downloads/raspberry-pi-os/
- Select: Raspberry Pi OS (32-bit) Lite, Download ZIP file
(Current version as of this writing is August 2020, Release date: 2020-08-20) - Download Balena Etcher: https://www.balena.io/etcher/
- Install and open Balena Etcher program
- Insert SanDisk Ultra 32 GB microSD card into card slot on your PC
- Select image: 2020-08-20-raspios-buster-armhf-lite.img
- Select target: microSD card location
- Click Flash! Button
- After flashing is complete, remove card (eject if needed) and re-insert card into card slot on your PC
- Add a blank text file with .ssh file extension anywhere in the boot directory
- Eject card and insert into the microSD card slot on Raspberry Pi
- Connect power and Ethernet cords to your Raspberry Pi and plug Ethernet cable into an open port on your router (or modem)
- Find the IP address assigned to your Raspberry Pi
- Login to the Raspberry Pi:
ssh pi@xxx.xxx.xxx.xxxUser password: raspberry
2Configure Raspberry Pi
sudo raspi-config
- Select Option 8, Update (Update this tool to the latest version)
- Select Option1, Change User Password (Change password for the ‘pi’ user)
- Update with your own secure password
- Select Option 2, Network Settings (Configure network settings)
- Select N1 Hostname (Set the visible name for this Pi on a network)
- -> Provide a meaningful name for your gateway
- Select Option 2, Network Settings (Configure network settings) again
- Select N2 Wireless LAN (Enter SSID and passphrase)
- -> Specify WiFi credentials here if you would like to administer your gateway via WiFi
- Select Option 4, Localization Options (Set up language and regional settings to match your location)
- Select I2 Change Time Zone (Set up time zone to match your location)
- Select Option 5, Interfacing Options (Configure connections to peripherals)
- Select P4 SPI (Enable/Disable automatic loading of SPI kernel module)
- -> Enable SPI
Arrow down to Finish to exit & reboot
If you will be using WiFi, remove the Ethernet connection, identify the new IP address assigned by your router
ssh pi@xxx.xxx.xxx.xxxUse your new password to login
3Adding the Sixfab 3G/4G Base Hat and Quectel Module
Read the getting started guide: https://docs.sixfab.com/docs/raspberry-pi-3g-4g-lte-base-hat-getting-started
Use the QMI interface with Base Hat guide: https://docs.sixfab.com/docs/qmi-interface-with-base-hat
Below are the commands you will need to run, which are also detailed in the guide above. Only run these set of commands once:
sudo apt update && sudo apt upgrade -y sudo apt-get install raspberrypi-kernel-headers wget https://raw.githubusercontent.com/sixfab/Sixfab_RPi_3G-4G-LTE_Base_Shield/master/tutorials/QMI_tutorial/qmi_install.sh sudo chmod +x qmi_install.sh cd files/quectel-CMSTOP!!
Make sure the short USB plug on the Sixfab Base Hat is left unplugged before running the installer.
sudo ./qmi_install.shPress Enter key to reboot
** Before proceeding to the next step, make sure you have a Twilio SIM card that has been preconfigured on www.twilio.com See steps at the end of this guide.
Now insert configured SIM card into the Sixfab Hat and plug in the USB cable into the Raspberry PI on the following slot: (photo)
cd files/quectel-CM sudo ./quectel-CM -s wireless.twilio.com
If you see the following line: udhcpc: "no lease, failing"
- Type Ctrl C
- Then you need to add the following line: denyinterfaces wwan0 to /etc/dhcpcd.conf
- The easiest way to do this is use the nano file editor: nano /etc/dhcpcd.conf
- Add this line at the bottom of the file: denyinterfaces wwan0 then hit Ctrl X, Y (to save), Enter
- Now reboot the Raspberry Pi using: sudo reboot
- Re-run the two lines above after logging in
Once the cellular modem is working properly, you should see the following line:
udhcpc: lease of 30.60.240.152 obtained, lease time 7200
You can open a new terminal tab, login, and try to run this command:
ping -I wwan0 -c 5 8.8.8.8If successful, you will see a similar output:
$ ping -I wwan0 -c 5 8.8.8.8
PING 8.8.8.8 (8.8.8.8) from 30.58.10.0 wwan0: 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=71.4 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=39.6 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=40.8 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=117 time=47.3 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=117 time=45.3 ms
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 11ms
rtt min/avg/max/mdev = 39.638/48.902/71.382/11.589 ms -
4Adding Python libraries and goTenna SDK
Recommend shutting down the Raspberry Pi, remove the USB-A plug and download the libraries over WiFi or Ethernet, not using the cellular modem. Once complete you can return to plugging in the USB again.
sudo apt install python3-pip sudo apt install python3-pip sudo apt-get install git sudo pip3 install cbor sudo apt-get install minicom lsof sudo apt-get install -y python3-spidev mkdir goTenna cd goTenna git clone https://github.com/gotenna/PublicSDK.git cd PublicSDK/python-public-sdk pip3 install goTenna-0.12.5-py3-none-any.whl wget https://raw.githubusercontent.com/remyers/Signal-Android/v4.58.5e-mesh/gotenna-public-sdk/mesh_gateway.ini wget https://raw.githubusercontent.com/remyers/Signal-Android/v4.58.5e-mesh/gotenna-public-sdk/mesh_gateway.py
Now we need to modify the mesh_gateway.ini file:
nano mesh_gateway.iniIn particular, we need to edit the serial port portion, change from:
serial_port = /dev/cu.USB Application Port1433423
To:
serial_port = /dev/ttyUSB2
Also, we need to edit the imeshyou section credentials for our node, with both login username, password, and GPS coordinates (14 digits after the decimal required):
[imeshyou]
# set the email address you use to login to https://users.gotennamesh.com/login
email = name@domain.com
# set the password you use to login to https://users.gotennamesh.com/login
password = password
# use default or set to a different friendly name
node_name = gateway
# enter the GPS location of your node, must have 14 digits after the decimal point
latlong = ["37.24500000000000", "-115.81500000000000"]You can now run the gateway with:
python3 mesh_gateway.py
5Finishing Touches
Add Sixfab auto-connect on reboot service to automatically start the cellular modem connection:
cd ~ wget https://raw.githubusercontent.com/sixfab/Sixfab_RPi_3G-4G-LTE_Base_Shield/master/tutorials/QMI_tutorial/install_auto_connect.sh sudo chmod +x install_auto_connect.sh sudo ./install_auto_connect.shIt will then ask for APN. Type in your APN and then press ENTER
(use wireless.twilio.com if you using Twilio SIM)
To check if the service is active you can type:
sudo systemctl status qmi_reconnect.service
Add service to automatically start the sms gateway Python program:
nano mesh_gateway_start.service
Add the following:
[Unit]
Description=Service to start mesh_gateway python script at boot
After=network.target
[Service]
ExecStart=/usr/bin/python3 mesh_gateway.py
WorkingDirectory=/home/pi/goTenna/PublicSDK/python-public-sdk
StandardOutput=null
StandardError=journal
Restart=always
User=pi
[Install]
WantedBy=multi-user.targetCtrl X, Y, Enter
Copy and start the new mesh gateway servce:
sudo cp mesh_gateway_start.service /etc/systemd/system/mesh_gateway_start.service sudo systemctl enable mesh_gateway_start.service sudo reboot
Log back into Raspberry Pi and verify service status:
sudo systemctl status mesh_gateway_start.service
You should see the following:
mesh_gateway_start.service - Service to start mesh_gateway python script at boot
Loaded: loaded (/etc/systemd/system/mesh_gateway_start.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2020-12-02 15:23:28 PST; 3min 23s ago
Main PID: 665 (python3)
Tasks: 3 (limit: 3862)
CGroup: /system.slice/mesh_gateway_start.service
└─665 /usr/bin/python3 mesh_gateway.py
Dec 02 15:23:28 SMS-Gateway-FUT1 systemd[1]: Started Service to start mesh_gateway python script at boot. -
6GPS preferred settings
(Note: Sixfab Hat with Quectel module must be seated and plugged in to run these commands)
sudo minicom -b 115200 -D /dev/ttyUSB2Please note you will need to manually type these lines as a copy and paste will modify the characters and result in ERROR:
AT AT+QGPSCFG=“autogps",1 AT+QGPSCFG="gnssconfig",3 AT+QGPSXTRA=0To exit from minimum app: Ctrl A, z, x, Yes (Enter)
7Twilio SIM card setup
- Navigate to All Products & Services/ Super Network/ Internet of Things/ Programmable Wireless/ Manage SIMs/ SIMs
- Click the blue plus symbol (Add SIMs) / Register a SIM
- Enter registration code (found on the back of SIM card; no spaces)
- After registration is complete, choose a unique name for your device
- Create or choose a Rate Plan (we use the Enabled services: Data, Messaging; 1000 MBs/Month; $1 Quota; Roaming Disabled)
- Activate your SIM (this can take from 15 seconds to a few minutes once you click activate)
- Copy & Paste the SIM SID to a NotePad or TextEditor for later use
- Navigate to All Products & Services/ Super Network/ Phone Numbers/ Buy a Number
- Select your phone number and click purchase
- Select SIM for your new device
- Select Programmable Voice & SMS
- Navigate to Programmable SMS Preview section at bottom of screen
- At SMS URL, select TwiML from the dropdown
- Click on the blue plus symbol to add TwiML Bin
- Replace the "YOUR_NUMBER_HERE" with your phone number in E164 format +1760xxxxxxx
- Replace the Friendly Name with something like "Delivery of outgoing messages: 760-xxx-xxxx”
- Click on Add TwilML Bin
- Click Save
- Navigate to All Products & Services/ Runtime/ TwiML Bins
- Click the red plus symbol
- Add a friendly name like "Receive incoming messages to 760-xxx-xxxx”
- Add the following code and insert your SIM SID underneath the following code line:
<?xml version="1.0" encoding="UTF-8"?>
Add this portion:
<Response> <Message to="sim:YOUR_SIM_SID_HERE" from="{{From}}"> {{Body}} </Message> </Response>Note: Insert your SIM SID number that you saved earlier on a Text Editor, paste after “sim:
- Click Create
- Click Save
- Navigate to All Products & Services/ Super Network /Phone Numbers
- Find your phone number in the list and click
- Scroll down to Messaging/ A Message Comes In, change to TwiML Bin
- Change drop down selection to Receive incoming messages to 760-xxx-xxxx
- Click Save
Done with adding SIM card and phone number in Twilio, now proceed to above step where you insert the SIM card into the Sixfab Hat
Richard Myers
