April Soil Moisture Sensor
Soil moisture sensor Wi-Fi enabled. It's based on Espressif's ESP32 S2 SoC and uses capacitive moisture probing.
Starting from
has orders / reviews
Ships from
Soil moisture sensor Wi-Fi enabled. It's based on Espressif's ESP32 S2 SoC and uses capacitive moisture probing. Also provide temperature sensor.
### Hardware ###
* ESP32 S2 module x 1
* Reset button x 1
* Boot Button x 1 (GPIO0)
* Functional button x 1 (GPIO2)
* Programming pinouts which adapter for ESP Flasher
* Led x 1
* temperature sensor x 1 (tmp112)
* Soil moisture sensor x 1 (PCB sensor uses capacitive moisture probing)
* Lithium Battery holder x 1
* USB Type-C for programming and battery charge
The project is modifying of the I2C Moisture Sensor project from Miceuz. Thanks for his source code
soil_esp32_S2.pdf
schematic
Adobe Portable Document Format - 26.18 kB - 12/04/2020 at 07:26
Preview
