Here is the helper function that, for every '\' in the path, it makes sure it is \\ so that printf works correctly...
parse_dir_add_slash.m
function [ret] = parse_dir_add_slash(dir_in)
% Search for the '\' character in the string
temp = strfind(dir_in, '\');
% For every \ in the string, make sure it is \\ so that it will print correctly
ret = '';
if ~isempty(temp)
for ii = 1 : length(temp)
if ii == 1
ret = [ret dir_in(1 : (temp(ii) - 1)) '\\'];
else
ret = [ret dir_in((temp(ii - 1) + 1) : (temp(ii) - 1)) '\\'];
end
end
end
% If the input string doesn't end with a \, add the rest of the string
if temp(end) < length(dir_in)
ret = [ret dir_in((temp(end) + 1) : end)];
end
Hi Ken,
Unfortunately, MATLAB will take the printf statement,
fprintf('Hi there\n Ken', '%s')
and generate:
Hi there
Ken
It will still process \n as a newline.
Yeah - there is probably one of the regular expressions or built in functions that you could use, but since I wanted to make this post useful to non-Matlab users, I went with the simple step by step, ultra-commented post.
Thanks!
Isn't there a function to substitute every \ with \\ in the string? That would fix the string in one fell swoop.
The other thing that occurs to me, on the assumption that matlab printf is similar to C printf, is you should be doing
printf("%s", path)
instead of
printf(path)
This way, no characters in path have to be escaped.
