Hackaday.io Hackaday.io
Sign up Log in
bstrip wire cut/strip
Open source high speed automated wire cutter and stripper
josh-pieperJosh Pieper
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.2k views
0 comments
17 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
2.2k
0
17
16
Team (1)
  • josh-pieperJosh Pieper
Join this project's team
  • jpieper/bstrip
hardware
ongoing project
CNC wire stripper moteus
This project was created on 12/07/2020 and last updated 6 years ago.
Description
Like many makers, I build a lot of cables. I also get tired of manually operating the side cutters and wire strippers, who doesn't?
Apparently, making DIY automated strippers is a thing, so I gave it a go with parts I had lying around the shop. This one is unique in that it is completely driven by brushless motors using moteus controllers, which makes it fast, and all the structural components are 3d printed, which makes it accessible.
It should work on wires roughly from 18 AWG up to 30AWG, although I've mostly tested it with 26 so far.
This hardware design and source code is all open source on github.
Being relatively cheap it just uses an off the shelf V blade cutter, so requires some tuning to balance stripping performance vs damage to the conductors. But on the plus side, the same cutting hardware can handle a relatively large range of wire sizes.
Project Logs
Collapse
  • mj5208 motors
    Josh Pieper • 12/30/2020 at 12:38 • 0 comments
    The brushless motor used in this project is now up for sale at mjbots.com!
    https://mjbots.com/products/mj5208
  • Overview video
    Josh Pieper • 12/11/2020 at 14:34 • 0 comments
    I made up an overview video on youtube:
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
We're building a DIYbio lab, including custom-building the equipment.
Project Owner Contributor
DIYbio Lab
progressthProgressTH
The 2015 Hackaday Prize
X-Ray for developing countries based on the Triboluminescence effect of scotch tape in a low-pressure environment
Low cost X-Ray (LCXR)
arseniodevArsenioDev
Official Hackaday Prize Entry
open hardware interactive midair screen
Hoverlay II
moritz-walterMoritz Walter
The 2017 Hackaday Prize
Customizable linear actuators made easy....and cheaper.
Open Actuator System: Maker Muscle
deezmakerDeezmaker
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "bstrip wire cut/strip", please tell us the reason.
Send message
Remove Member
