1Hardware Connection
2Software Preparation
- Check and make sure you have installed the ameba 1 board to Arduino IDE via adding this link into “additional boards manager URLs” under “Preference”, and install it in “board manager” under “Tools”, https://github.com/ambiot/amb1_arduino/raw/master/Arduino_package/package_realtek.com_ameba1_index.json
- Download the ThermoGun source code you find in this repository to your Ameba1 RTL8710 boards using arduino IDE.
- In order to connect to WiFi and MQTT server, you need to key in your WiFi SSID, WiFi password, MQTT username and MQTT password,
- MQTT username: same as your amebaiot.com username
- MQTT password: same as your amebaiot.com password
Michael Zhang
