- Bugfixes
- 3.3V regulator added so the SD card isn’t supplied by the reference output of the USB-Serial bridge.
- Unused inputs on SD card buffer IC are grounded. Stock design leaves them floating.
- PCB layout fixed to follow standard PCB design guidelines including best practices for Trinamic drivers from the TMC2209 datasheet.
- Direct ground return path provided for each driver with minimal sharing between channels. Stock config has both channels on 4 drivers share a single circuitous path around the board that introduces current sensing errors.
- 2x 10uF 1206 ceramic capacitors added as close as possible to each driver chip.
- Ground planes maximized with via stitching to reduce noise and losses.
- Improvements
- Comes with Micro-B USB port standard. Mini-USB ports are not recommended on new designs because the port itself wears down over time and needs to be replaced, which requires soldering. With Micro-USB the cable wears down and can be easily replaced. The PCB layout supports both types.
- Added second fan control channel with 2 fan connectors for the controller and hotend fans. There is a jumper to select if they are always on or controlled by pin 29/A2 through marlin. They can be setup to turn on/off with either the hotend or stepper motors in marlin.
- 3-pin probe/bltouch header added with jumper to select beeper/probe for pin 27. Bltouch wire colors labeled on probe and Z stop connectors.
- 15A ATO fuse added
- ESD protection diodes added to 24V input, USB 5V+data pins and BLtouch data pin.
- All other external inputs protected with series resistors and clamp diodes to protect against voltage spikes and accidental shorts during setup.
- Low RDS(on) MOSFETs for bed and hotend stay cool to the touch with no heatsink necessary.
- VREF trimmers replaced with high quality sealed units with a non-conductive screwdriver port.
- .15ohm sense resistors, trimmed to 1.13V (580mA) for X/Y/Z axis and 1.27V (650mA) for E axis.
- TX and RX pins added to EXT-A2 jumper, to support adding an ESP8266 module for wireless printing
- Jumpers
- USB_POWER header allows enabling/disabling 5V input from USB jack.
- JP2 allows selecting Beeper or Probe on pin 27, external pin 27 board not necessary to add probe.
- JP_FAN1 controls whether hotend+controller fans connected to FAN1A and FAN1B are always on or controlled by pin 29/A2 through marlin.
- Status LEDs
- White LEDs running from 5VOUT on each driver show when they have power.
- Red LEDs on driver DIAG pins to show when drivers have a fault condition
- Red LEDs on hotend and heated bed MOSFET gates show when they are heating.
- Blue LEDs on FAN0 and FAN1 show when part cooling and controller+hotend fan are running
- Software Configuration
- Comes with Arduino bootloader installed and latest Marlin 2.0 stable
- Linear advance enabled with 0.0 k factor by default, which is equivalent to disabling. Can be set with GCODE M900 command, such as with Cura Linear Advance plugin.
- Babystepping enabled
- S-curve Acceleration enabled
- FAN1 setup as hotend cooling fan, so it should run whenever the extruder is over 50 degrees, which should be effective for most use cases.
steenerson
Arnov Sharma
ajlitt
Laine Walker-Avina
Fantastic list of improvements. I suggest you promote this to BIGTREETECH to produce it at a good price. They are well known as a supplier of improved replacement boards for 3D printers. Have you produced a prototype yet?
