11Step 11
Now on to the motherboard mounting plate. You'll need to countersink the holes, these are marked in the drawing.
12Step 12
Attach the screen mounts. Use mini spring clips to hold the pieces together while gluing.
13Step 13
14Step 14
Insert the M2.5 x 10 CSK screws, fix with a washer and two screws - to raise the motherboard up slightly.
15Step 15
Screw in the M3 x 15mm Hex Spacers.
16Step 16
Install the motherboard (use M2.5 lock-nuts) and other components.
