1X-PC Frame Assembly
Follow the pictures to assemble the frame. All the parts are fixed together with liquid solvent cement - I used a syringe with a blunt needle but you can also use a paint brush.
I've labeled some of the parts to help put them in the correct position.
Start with the top frame strengthener.
2Step 2
3Step 3
Now on to the inner frame.
Note: This picture is from an earlier version. I've moved the position of the hole in the bottom plate to the other side in the current version.
4Step 4
5Step 5
6Step 6
7Step 7
8Step 8
9Step 9
10Step 10
