Full inverted low leg possible within workspace with max 50mm inline tension turnbuckle. The kink on the lower leg limits the degrees on inverted side.
![](https://cdn.hackaday.io/images/9990881608749981016.jpeg)
A project log for K3lso Quadruped
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
