3090hz
03/24/2021 at 13:53 • 0 commentsGetting somewhere on the loop frequency! We Started of at around 650hz. This is 1 motor over 1/4 available channels.
Futher more I got a bit crazy and ordered two additional 4-Channels FD baords. So I can run each motor on a individual channel. So in total the robot will have 12-Channel CAN-PCI(FD) . Which would increase the individual frequency for each motor.
UP! Xtreme custom kernel
03/13/2021 at 09:22 • 0 commentsPatched the #UPboard #UPXtreme stock kernel 5.4 with RT-PREEMPT. @UPbridge_gap 🙃 also the pin control is confirmed working!
You can find my build steps here:
https://github.com/raess1/UPxtreme-RT-kernel/blob/main/README.md
#k3lso #quad #quadruped #robotics #Ubuntu #ros #RT #PREEMPT https://t.co/eiMUz7scP6
New covers!
03/04/2021 at 21:04 • 0 commentsYep I think I have something that I could live with..
What do you guys think?Quick and dirty half test cover for shape verification!
Impact bar.
03/01/2021 at 22:14 • 0 commentsI am adding a impact bar.
The new idea with back/front cover is to design around the impact bar. The back cover has an internal plastic structure and a outer molded CF cover. not a fan of the sharp intersection between top/bottom cover.
Back cover prototyping
02/20/2021 at 09:12 • 0 commentsA very quick draft of half the back cover. Design purposes only.
#k3lso #quadruped #quad #3Dprinting #raise3d #robotics #bldc #ros
Half test print for top cover
02/18/2021 at 15:59 • 2 commentsA very rough first print for half top cover. Needed something to touch and visualize IRL before going further with covers. And No I will not use home 3D printed covers.
Friday picture
02/13/2021 at 00:44 • 0 comments
#k3lso #quadruped #quad #ros #robotics #UPXtreme #ROS #unitree #bostondynamics #laikago #mjbots https://t.co/rIo9h7ytxO -
Test assembly of CF
02/10/2021 at 22:51 • 0 commentsTest assembly of CF leg with new lower design/foot. Everything fits perfectly! Happy with the more rough looks!
Weight data comparison:
Upper:
CF = 219g
7075 = 315g
reduction 43%
Lower:
CF = 185g
7075 = 254g
reduction 37%
Motor mount:
CF = 99g
7075 = 145g
reduction 46%
#k3lso #quad #quadruped #UPXtreme #cnc #robotics #ros #design #fusion360 #carbon #leggedrobotics @UPbridge_gap
New parts.
02/10/2021 at 18:14 • 0 commentsNew parts. One full set of CF legs for the robot and also a set of the new lower leg design in 7075.
The foot mold fitted perfectly! The CF legs are about 38% lighter then 7075.
Nintendo Switch multi-camera streaming
02/04/2021 at 11:07 • 0 comments
