VFD watch
bringing an old VFD back to life
Public Chat
I'm working on a VFD watch.
This is my first try with this type of display. It must be fun and i'll learn a lot.
This is a VFD based watch and consist two major parts. First part is VFD breakout board it has parts to provide VFD required 28v dc voltage and 5v ac voltage. also the ULN2803 and 74HC595 ICs allow to control whole VFD with 3 pins. Second part is VFD controller board it has a RTC , microcontroller , buzzer and all other parts that complement the first part and form a WATCH...
VFD_DigiPro_V4.ino.pro.hex
upload the hex file to your ATTiny167 microcontroller
hex - 31.47 kB - 01/02/2021 at 11:24
Download
cover.DXF
laser cut cover
AutoCAD DXF - 33.09 kB - 01/02/2021 at 09:21
Download
VFD controller board-Final Version.pcbdoc
pcbdoc - 367.00 kB - 12/28/2020 at 20:52
Download
Schematic_VFD Controller Board.pdf
Adobe Portable Document Format - 74.27 kB - 12/28/2020 at 20:52
Preview
VFD breakout board-SMD.pcbdoc
VFD breakout board
pcbdoc - 309.00 kB - 12/24/2020 at 18:10
Download
View all 7 files
  • 1 × MT3608 DC-DC boost converter IC
  • 1 × 22uh inductor
  • 1 × SS34 Discrete Semiconductors / Diodes and Rectifiers
  • 1 × 2.2k 1206 resistor
  • 1 × 100K 1206 resistor
View all 27 components
  • Cover
    Ben Mo • 01/02/2021 at 09:16 • 0 comments
    I've designed and made a cover for VFD watch...
  • Parts come together
    Ben Mo • 12/31/2020 at 09:30 • 0 comments
  • Breakout Board Connector
    Ben Mo • 12/31/2020 at 08:25 • 0 comments
    Unfortunately i couldn't find a suitable connector for my purpose...So i decided to make it.
    I ordered some Nokia 3110 battery connector to extract their flexible pins.These pins have the exact height that i need.
    Also, I soldered M3 brass insert nuts as on-board spacer to avoid using extra screws when i'll assemble the parts
  • Programming Time
    Ben Mo • 12/31/2020 at 07:43 • 0 comments
  • VFD Controller Board
    Ben Mo • 12/28/2020 at 20:51 • 0 comments
    This is the controller board that has a DS3231 RTC chip , an Attiny167 microcontroller , a Buzzer and some other component...
  • VFD breakout board
    Ben Mo • 12/24/2020 at 18:06 • 0 comments
    I've designed this board for my VFD. it consists of a boost converter based on MT3608 , AC voltage provider with ATTiny13 microcontroller , ULN2803 and 74HC595 ICs to control all grids and segments with 3 pins and also has two ws2812b RGB led as backlight especially used in alarm clock feature.
  • VFD controling method
    Ben Mo • 12/24/2020 at 16:19 • 0 comments
    I used combination of ULN2803 and 74HC595 to control all VFD just using 3 pins.
  • MT3608 & ATTiny13 test PCB
    Ben Mo • 12/24/2020 at 15:57 • 0 comments
    Testing boost voltage circuit with fixed output voltage also program and test Attiny13 to provide a 5v ac voltage for VFD filament.
  • Filament AC voltage
    Ben Mo • 12/24/2020 at 15:51 • 0 comments
    For filament we can use DC or AC voltage but AC has superiority over DC. If the filament is driven with a DC voltage there will be a voltage gradient across its length. This means the end of the display with the more positive filament voltage will have less of a differential to the anodes, and thus will be dimmer than the negative end of the filament due to the potential gradient effect.
    http://insanity4004.blogspot.com/2017/03/p170-dh-vacuum-flourescent-display.html
    https://www.qsl.net/m0ayf/VFD-Regen.html
    to producing AC voltage i decided to use a microcontroller, in this case i choose an Attiny13 .
    for achieving a 5v 60hz ac voltage i programmed two pins of Attiny13 as output and switching them on/off respectively with a 8 milliseconds delay.
    void setup() {
      pinMode(0, OUTPUT);
      pinMode(1, OUTPUT);
    void loop() {
      digitalWrite(0, HIGH);
      digitalWrite(1, LOW);
      delay(8);
      digitalWrite(0, LOW);
      digitalWrite(1, HIGH);
      delay(8);
  • MT3608 circuit test pcb
    Ben Mo • 12/24/2020 at 14:22 • 0 comments
    It works fine and boost 5v up to 28v
View all 12 project logs
Vlad V wrote 01/28/2022 at 18:26 • point
Im going to make my own out of an Triumph-Adler 80c
it uses the same display, but i have the whole calculator including the power supply so i'll just modify that. I hope to use a teensy microconroler to control it.
Paul Andrews wrote 05/24/2021 at 18:47 • point
I'm just developing my own VFD board and the MT3608 looks like an interesting alternative to the design I came up with on webench. What was the spec of the 22uH inductor you used?
Ben Mo wrote 05/25/2021 at 03:45 • point
your works are great and i excited to see your new design.
I've used CD54 and CD32 for 22uH inductor and both work great.
Mitsuru Yamada wrote 01/02/2021 at 12:30 • point
Nice project ! In the 1970s, my home calculator was a VFD with a beautiful green display.
Ben Mo wrote 01/02/2021 at 14:02 • point
Thank you dear @Mitsuru Yamada
"old is gold"...  i'm agree with you these displays are so beautiful
Ben Mo wrote 12/31/2020 at 07:32 • point
Thanks dear @Mike Szczys
The controller board has an AMS1117-5v regulator that feeds whole the device.a 9v/1a dc adapter plugs into dc jack and supplies the input voltage of AMS1117.
Mike Szczys wrote 12/30/2020 at 23:15 • point
I'm quite interested to see this one come together. What power source will feed the boost converters for the VFD?
