This is a VFD based watch and consist two major parts. First part is VFD breakout board it has parts to provide VFD required 28v dc voltage and 5v ac voltage. also the ULN2803 and 74HC595 ICs allow to control whole VFD with 3 pins. Second part is VFD controller board it has a RTC , microcontroller , buzzer and all other parts that complement the first part and form a WATCH...
Ben Mo
Tijl Schepens
Collin Matthews
Im going to make my own out of an Triumph-Adler 80c
it uses the same display, but i have the whole calculator including the power supply so i'll just modify that. I hope to use a teensy microconroler to control it.
