voltage booster
12/24/2020 at 13:54 • 0 commentsFor Grids and Segments you need to boost voltage up to 30v.
I've used MT3608 dc-dc boost converter IC for this purpose and boost 5v to 28v.
This is the Schematic of the boost circuit you can find in the datasheet :
there's several arrangement of R1 and R2 to achieve desired output voltage. this is my arrangement for maximum output voltage:
finally i choose 100K and 2.2K...
Find Pinout
12/24/2020 at 13:34 • 0 commentsI've determined VFD pinout myself
pin pitch - 2.7 mm
left to right:
1-element
2-G1
3-G
4-G2
5-F
6-G3
7-E
8-G4
9-D
10-G5
11-G6
12-DP
13-G7
14-C
15-G8
16-B
17-G9
18-A
19-element
