Testing the Base, bad news for IR
12/31/2020 at 01:04 • 0 commentsThe base dimension is perfect, but is a bit light, the tree itself must be glued to the base to keep it loked.
The bad news is about an issues on PCB. For some still unknow reason the IR circuit seems to be broken.
I've asketd a friend to land me a RGB remote to test the feature, but it seems to be not working.
Now I'm not sure if it is an error on the circuit itself or if it is an issue with software.
More troubleshoot time is required. -
Creating a base for the tree
12/24/2020 at 15:01 • 0 commentsThe PCB is quite lite, so I would like to create a base to anchor it.
I've started the design, right now I'm printing the first prototype.
Nicolò
