PelletMon - IoT for central heating boiler.
Monitor pellet boiler status via CAN bus, measure fuel usage - RE + engineering = profit !
WHAT AND WHY?
Our old boiler was previously connected to my IoT system. After replacing the boiler with a new one, we no longer have this option. So why not introduce it to a new boiler?
THE TARGET
The goal of the project is to reverse engineer the CAN communication of the new boiler and expose real-time data to the IoT. By the way, the HC-SR04 sensor will measure the fuel level in the tank.
DESIGN
The project will have its own PCB. Communication with the outside world will be carried out using ESP32 and fuel level measurement using HC-SR04. The SN65HVD230 chip will be used as the CAN transceiver. The software will be written in the Arduino environment in C ++ and will be powered with my IoT framework - ksIotFrameworkLib.
  • Latest changes
    h4rdc0der06/22/2023 at 18:42 0 comments
    CAN issues have been resolved over the last few months.
    It turned out that the problem was in the software and was related to CAN frame collisions.
    The issue has been eliminated and I have returned to the native TWAI interface.
  • Version 2: PCBs arrived & assembled
    h4rdc0der02/06/2023 at 20:41 0 comments
    A few days ago, the PCBs arrived. Soldering under the microscope was even pleasant, however, the ESP32 module did not want to cooperate. After a few hours, however, everything worked and the board started working.
    Currently, the module has been permanently mounted and has replaced the previous version.
    It is worth noting that due to problems with the TWAI component, I was forced to write my own CAN handling library (based on other available on the network).
    More details about the library soon :)
  • Version 2B
    h4rdc0der01/11/2023 at 20:38 0 comments
    I'm currently working on upgraded board version, which features:
    • Decreased power consumption
    • ESD protection / EMC improvements
    • Better connectors
    I've removed fuel sensor support (never used).
  • Elektronika Praktyczna spotted my project!
    h4rdc0der11/25/2022 at 23:06 0 comments
    I've discovered this small note in Elektronika Praktyczna written in polish about PelletMon project (11/2021). They've previously spotted another project - Energy Monitor. It's always good to read about own project in brand press. Thanks!Brak dostępnego opisu zdjęcia.
  • Everything now runs on VideNet protocol
    h4rdc0der07/30/2021 at 05:47 0 comments
    Great success!
    Few days ago I've finished CAN component that is able to handle VideNet protocol. Adding new request takes only few lines of code.
    Currently supported features are:
    • Ability to turn on / turn off controller.
    • Ability to read / set hot water mode.
    • Ability to read / set central heating mode.
    • Ability to read kettle temperature.
    • Ability to read hot water temperature.
    • Ability to read burner power (%).
    • Ability to read fuel usage sum (kg).
    Special thanks going to:
  • Introducing remote control
    h4rdc0der07/09/2021 at 07:40 0 comments
    I've found Vide-Net protocol specification (VideNet is an original RC module). With that knowledge remote control is now possible!
  • Fixed and working!
    h4rdc0der03/06/2021 at 10:36 0 comments
    After removing the terminating resistor, the problems with the boiler disappeared. The device has been working continuously for several days without any problems.
    Final mounting - transparent enclosure, SMA antenna:
  • Bad things happened
    h4rdc0der03/03/2021 at 21:31 0 comments
    It looks like with 120 ohm resistor, I have introduced excessive termination that led to errors in CAN transmissions. I had to unsolder termination resistor from my board and trim my cables to work properly as CAN stub.
    Enclosure arrived today, so I have mounted everything inside.
    It requires more testing this time, but I hope that issue is fixed.
  • Testing
    h4rdc0der02/28/2021 at 20:44 0 comments
    Today I prepared the cables and prototype software to retrieve data, then connected everything to the heating boiler CAN-bus and communication with MQTT worked properly.
    Example dasbhoard:
    Testing connection and current consumption.
    What's next?
    I need to route everything properly, get an enclosure and add fuel level sensor. It will take few days as I have to order cable organizers etc.
  • Tests done, everything works!
    h4rdc0der02/26/2021 at 12:56 0 comments
    Before connecting my device to the boiler, I made sure that all interfaces were working.
    There was a problem with the R1 resistor, which made the CAN bus not working, but it turned out that it was enough to correct the weld. There is working two-way communication between the two PCBs. The fuel level sensor leads have also been tested and everything is fine.
    Now all that's left is programming and installation on the boiler :)
View all 15 project logs
Szymon wrote 01/22/2025 at 08:35 point
Hey,
I've just created account here to tell you that you're probably first one that reverse engineered that Ingeno Touch product by Estyma.
I've been looking for 1.5 year for similar solution to solve in some reasonable way tracking of used pellet, because that data how much got burnt in specific period of time having data from some weather station would let me know if my efforts to improve my home have given some effects, If possibly i would really enjoy sharing what you have got there ;-)
Andreas wrote 10/28/2024 at 12:51 point
This project looks great. I would like to test it, but I don't know how to start. Anything new about the repo?
nuxeh wrote 03/13/2024 at 19:37 point
Can I just say that this is one of the most beautiful PCB designs i've ever seen
h4rdc0der wrote 03/13/2024 at 20:09 point
Thank you :) Still some room for improvement :)
Piotr Antosik wrote 02/07/2024 at 18:23 point
Hi, project repo is archived? GH show 404 error
h4rdc0der wrote 02/08/2024 at 07:29 point
ATM yes, github repo is hidden as I don't like ppl to copy this board without consideration of things like the need of isolation or lack of CMC for filtering. I plan to respawn the repository with autoreleased binaries soon.
imsa8800 wrote 04/29/2023 at 20:19 point
Hello,
great work !
I have built it and it did work out of the box. (NodeMCU Board + CAN Module).
Have now integratet my kettle with MQTT into loxone automation !!
Greetings from Austria
h4rdc0der wrote 06/22/2023 at 18:40 point
Cool, happy to see that it's useful for people!! Greetings from Poland.
piomark wrote 01/05/2023 at 22:03 point
Hi, first of all great project!
How is SR04 sensor working? I was trying to use same sensor type for pellet level monitoring as well but unfortunately it's not that stable. It looks like when the level goes down uneven surface of the pellets, and the container walls, are causing some interference which in turn leads to incorrect readings. I've tried VL53L0 but it burned after a while :(
h4rdc0der wrote 01/12/2023 at 09:23 point
Hi, thanks a lot :).
When it comes to measuring the pellet level using an ultrasonic sensor, it turned out that the implementation was unnecessary. Why? Simply, because there's enough info transmitted over CAN bus.
What's more, there are no resistors and ESD protection for the pins on the board. It is therefore possible that long wires would induce transmission line phenomena, which in itself could cause problems.
The new revision of the board does not have outputs for the HC-SR04 at all.
Krzysztof wrote 01/13/2023 at 11:05 point
How does your furnace measure the level of pellet? Mine only has "fuel low" ultrasonic sensor (binary info, either "over reserve" or "under reserve"), but when it detects low level, it is configured to interpret that as "10kg left" and then just counts down usage based on feeder.
h4rdc0der wrote 01/13/2023 at 19:12 point
There's no "real"/sensor based measurement, it just knows how long the feeder was active. Then (using some HMI input) is simply able to calculate real usage.
helge wrote 06/09/2022 at 09:26 point
The large corporate logo suggests this is a sponsored project.
h4rdc0der wrote 06/09/2022 at 09:44 point
You mean JLC logo or Viteco? Not sponsored in any way :)
Michael Lytzen Hansen wrote 05/27/2022 at 18:36 point
Cool project -I have just started on a similar one :)
Where did you find the VideNet protocol specification?
h4rdc0der wrote 06/09/2022 at 09:04 point
Thanks!
At first I have tried to sniff CAN packets. The device outputs some data, but it's only raw Module-To-Module data. You can read some interesting info from that, but no control over parameters is possible. To reverse engineer communication, you must pair original VideNet module.
I've found research done by Kem Klattrup at https://github.com/kematic. This repository is linked in firmware README.md on pelletmon's github. There is almost complete protocol specification (https://github.com/kematic/pelle/wiki/Vide.Net-Bia24). I've talked with Kem to exchange some info about my kettle specification, because there are little differences in handling error (alarm) messages.
Michael Lytzen Hansen wrote 06/19/2022 at 16:30 point
Super - Thank you!
