min led.pdf
Minutes digits schematic.
Adobe Portable Document Format - 110.01 kB - 01/23/2021 at 04:11
Preview
hour led.pdf
Hour digits schematic.
Adobe Portable Document Format - 110.01 kB - 01/23/2021 at 04:10
Preview
CLOCK BOARD.pdf
Main clock schematic.
Adobe Portable Document Format - 1.55 MB - 01/23/2021 at 04:09
Preview
MAINR11_DST.X.production.hex
I code in ASM and there are many sub files. Here is the hex file ready to download into the MCU (if you ever need to). Buy or design your own hardware and write the application as you like. Once you're done, just load back this hex file!
hex - 19.44 kB - 01/17/2021 at 01:38
Download
70degbrckt201219 v1.stl
STL file to print the 3D stands
Standard Tesselated Geometry - 232.60 kB - 01/02/2021 at 04:00
Download
LED4INT00_5V.PcbDoc
PCB layout file
pcbdoc - 1.65 MB - 01/01/2021 at 13:13
Download
