01.jpgJPEG Image - 1.27 MB - 12/31/2020 at 01:06 |
02.jpgJPEG Image - 1.30 MB - 12/31/2020 at 01:05 |
03.jpgJPEG Image - 1.15 MB - 12/31/2020 at 01:05 |
04.jpgJPEG Image - 1.24 MB - 12/31/2020 at 01:05 |
05.jpgJPEG Image - 1.22 MB - 12/31/2020 at 01:05 |
I was hoping to find marking codes on the BGA chips while decapping the main chip(SiP), but found nothing. So I decided to look inside the PCB layers and hopefully get some clues.
The delayering process was straightforward, using Sandpaper, Double-sided tape, and a piece of glass on which I mounted an extremely thin PCB.
PCB delayering was a success, I uncovered 3 part numbers:
PCB has 5 copper layers, with the ground plane in the middle.
PCB reverse-engineering begins with a weird discovery: a capacitor from flex PCB that is connected to the pin on BLE SOC U9, unusually far away from U9.
Button connected to the main PCB with 2 traces from flex PCB, another strange design choice.
The chip design continues to get weirder: i2c lines are not connected to the pads on the right side! This means the second i2c temperature sensor located on flex PCB is useless.
"2008-002100-21 Project-D" has a lot of test points where I want to connect JTAGulator and GoodFET, in order to do this I need to order another Halo.
Regarding the "strange cap", it's probably a pseudo differential routing for the microphone signal like what is described here: https://ez.analog.com/audio/f/q-a/3326/adau1961-alc-function
For the "missing" I2C did you check other layers?
FYI U1 is definitely the MAX86141 and those two PPG LEDs look like Osram SFH7016 and CT DBLP31.12
Hey, you are right! I just double-checked all 3 parts & updated my component list
Whoa! This is an incredible teardown. I'm amazed at the level of detail, nothing can stop you from unlocking the secrets. I really enjoyed this, thank you!
some Halo software sniffing and the like on reddit:
https://www.reddit.com/r/AskReverseEngineering/comments/zkc3fp/amazon_halo_app_to_intercept_halo_band_and_view/
