Hackaday.io Hackaday.io
Sign up Log in
250W DC-DC Boost Module Test & Reverse Engineering
nqtronixnqtronix
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
6k views
0 comments
10 followers
  • Description
  • Details
  • Files 13
    • View all
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
6k
0
10
14
Team (2)
  • nqtronixnqtronix
  • romainRomain
Join this project's team
hardware
completed project
module reverse engineering boost dc-dc
This project was created on 01/01/2021 and last updated 4 years ago.
Description
This DC-DC boost module seems to be fairly popular due to its wide operational range, high power and low cost (about 3-5€ on aliexpress). It's build with an aluminium core PCB, to cool it can be attached to a heat sink with thermal adhesive tape.
It converts 9-48V to a maximum of 48V, the output power is rated at 250W but effectively limited by the max input current of 6A. The efficiency is about 90-95%.
I was curious on how it works, so I desoldered the inductor and reverese engineered the PCB. It was almost imposible to see the traces, the schematic was derived from a bunch of continuity tests, so there might not be 100% correct. Afterwards I did a quick performance test where I placed it on a small metal case. At 100W output the transistor temperature was only 45°C, at lower loads you propably won't need any extra heatsink at all. Not that this does not have over temperature protection build in, you must verify your application!
Files
JPEG Image - 734.66 kB - 05/31/2022 at 17:38
Preview
latest revision
Portable Network Graphics (PNG) - 162.34 kB - 06/02/2022 at 16:04
Preview
JPEG Image - 11.03 MB - 01/01/2021 at 13:08
Preview
JPEG Image - 11.11 MB - 01/01/2021 at 13:08
Preview
JPEG Image - 8.06 MB - 01/01/2021 at 13:08
Preview
View all 13 files
Project Logs
Collapse
  • Update 3: This should be the final one...™
    nqtronix • 06/02/2022 at 16:10 • 0 comments
    One more update by OneOfEleven, he send me me this:
    Found some errors in the schematic nqtronix and added the component values as well. This should now be the final and correct schematic ..
  • Update 2: New PCB revision
    nqtronix • 05/31/2022 at 17:43 • 0 comments
    Another helpful update by OneOfEleven:
    Your PCB looks to be a 2014 version, mine appears to be a 2018 version (only difference is R1 & R20 I think). Here's a piccy of mine you could add if you wanted to help others.
  • Update: Complete Schematic by @OneOfEleven
    nqtronix • 05/31/2022 at 14:56 • 0 comments
    OneOfEleven has created a correct and complete schematic of this module, you can find it in the project files or below. Thank you for sharing this!
  • Additional Information
    nqtronix • 12/11/2021 at 15:49 • 0 comments
    By chance I found another post about this dcdc converter with in-depth measurements. Check it out here: https://lygte-info.dk/review/Converter DC-DC 10A 8.5-48V to 10-50V 250W UK.html
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
4 channels to control 4 AC Appliances. No switching noise, high load handling and comes with better control the SSR MODULE.
Project Owner Contributor
4 Channel SOLID STATE RELAY Module
sagar-001Sagar 001
RF2126 module received from Amazon. It did not work for 2.4GHz as announced. So tuning was performed.
RF2126 module (amazon) tuning for 2.4GHz
denys-zaikinDenys Zaikin
This is a custom Module designed to drive DC Motors.
L298d Motor Driver Module
mbsg99mbsg99
How to make some practical devices with a cheap compact ZVS driver module sold on AliExpress for less than $5.
What can you do with chip mini ZVS Driver
mircemkmircemk
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "250W DC-DC Boost Module Test & Reverse Engineering", please tell us the reason.
Send message
Remove Member
