1Hacking a MG92b : Open the servo
Remove the cover that has the 4 screws, exposing the motor and PCB.
2Hacking a MG92b : Remove PCB
Unsolder all wires and remove genuine PCB
3Hacking a MG92b : Wiring the servo
Re-use the servo wires and solder 2 short wires on the motor, 3 short wires on the potentiometer.
4Hacking a MG92b : Wiring control board
Solder the wires on the tiny control board.
5Hacking a MG92b : Protect control bard
Use a a piece of heat-shrink sleeve as an envelop, or print a small 3D case to protect the control board.
pat92fr
